Just picked Up my CR-10 smart and got it assembled but the unit is not powering up. The switch at the back is lit but no power to the front screen. Seems the power button on the side is not functioning. I’m sure I’m missing something being a newbie, any advice will help. TIA.
Id suggest double checking the wireing, i know ot sounds simple, but it fixes more problems than it causes.
If the power button lights up, is the control board getting power? Usually there may be a light somewhere on it, aswell as some random fans being started.
If yes to above then doublecheck the ribbon cable to the screen.
Thanks for the quick reply. The light on the power switch at the back is on but no fan and no power to the front controls. I did power off and check the ribbon cable to the front control panel and it was secure. Should the round power button on the side light up when pushed, because it’s not.
I dont have your printer, but did you try flicking the switch on the back (power) then press the silver button on the side?
Yes the power button on the rear lights up and that is all I get.
on the PSU (power supply unit) there might be a switch to change between 240v and 120v if it’s set wrong this might be the issue
Thanks Glenn. Yep the power supply was switched to 220.
