Say you download a STL of a key is there a way you can lay the file flat vs it being vertical
When you convert it to gcode using a slicer (let’s say, Cura), you will get an option to position the part in whatever orientation suits you. In cura, click on the part and on the left hand side of the screen a series of icons will appear. The third one down is rotate.
Fantastic thanks i’ll give it a try
