Does anyone have any input on how to get this to compile? also can anyone confirm what they defined to get sensoless homing to work aswell as use the bl touch for the z homing.
The values you put in for the Probe to Nozzle offset are invalid. The error is indicating that the values for NOZZLE_TO_PROBE and PROBING_WIDTH produce an invalid value.
I have sensorless homing and BL Touch working on a Robin Nano V3 so I’m not sure it’s applicable.
Check the values for the two defines listed in the error message.
I found the issue for it to sucessfully compile. It was #define LEVEL_CORNERS_INSET_LFRB { 50, 50, 50, 50 } // (mm) Left, Front, Right, Back insets
The stock values are 30,30,30,30
I changed them to 50 to accomidate for the bltouch offset (-44,-12) and will adjust it more once i give it a go.
@Jason Yeah it was nice to finally meet you, and thank a bunch for giving me the idea to look around again. I ended up stumbling across this line which was simmilar to what the compilation error was.
