This post is for all the resin printers.
Lets see that support game, and some of your tips and tricks. I personally will use auto supports for the platform of my print (removing) the ones that aren’t needed. I then change my Contact depth to 0.12 and add med or heavy supports (depending on what im supporting.) I then use the edit support, then light again with low contact depth. I use the joint of the support and spider web the lights out. Here’s a pic for an example.
