I’ve been thinking about how much of this hobby gets learned the hard way: failed prints, quality issues, printer maintenance (or lack thereof), improper file preparation, and so on.
Looking back, there’s probably a handful of things that would’ve saved most of us hours (and a lot of filament).
Mind you, a lot has changed since the early Ender 3 days… especially now, with the standard of quality and speed we get with modern printers. Now, printing something can be as easy as selecting a file from your phone and hit print (e.g., Bambu Handy). I imagine newcomers might be missing out on some of the finer details of part optimization, slicing, and customization.
So I’m curious: if you could go back and give your beginner self some advice, what would it be?
I’m always interested in swapping tips and tools that make 3D printing easier for everyone, I think a thread like this could be a great resource for newcomers, and honestly for those of us who’ve been at it a while too. Share your lessons, big or small!
For me the biggest frustration of the early days (2017…) is nozzle wear and how it degrades print quality in ways that is baffling.
I wish somebody told me that stringing, layer lines, gaps, blobs and sizing issues could all be a badly worn nozzle it would have saved a ton of time re calibrating cleaning and frustration trying to fix.
Nozzles wear and some wear fast! I have had nozzles wear out from start to finish a long print with a glow filament.
Ich würde nach einer Halterung suchen, bei der der Verkäufer ausdrücklich beide exakten Gimbals nennt und idealerweise mit Fotos zeigt, wie sie jeweils befestigt wird. Derselbe Grundsatz gilt bei Simsinos Casino unter https://simsinos-de.de/: Konkrete Angaben und Bedingungen sind aussagekräftiger als allgemeine Werbeformulierungen. Das Wort „universell“ allein würde mich nicht überzeugen. Welchen Monitor und welchen Akku möchtest du verwenden? Damit könnten andere Gewicht und verfügbaren Platz besser einschätzen und vorgeschlagene Halterungen leichter vergleichen.
Agreed. I’m a big proponent for troubleshooting one variable at a time! It’s easy to rush and throw a few different parameters at once, but it’s a great way to learn what variables are really making a difference in your prints
One thing I wish I knew when I started 3D printing is that small changes can make a big difference. Things like print speed, material, and bed level can affect the final print. I also learned that it is better to test one setting at a time to find what works best. For people who need help making parts or testing new designs, RapidMade is also worth checking out for different 3D printing options.
The one-variable-at-a-time point is what took me longest to appreciate. Early on I’d change speed and temperature together, then have no idea which one fixed the problem. Writing each change down, even on scrap paper, made it much easier to repeat good results later. Bed level deserves more attention than it usually gets too; a slightly off first layer can make everything downstream look like a settings problem. I’d add keeping filament dry to that short list of basics worth checking before touching slicer parameters.
Writing each change down is the part I’d second most strongly; memory is a poor record when you’re several tweaks deep. The filament-dryness point is easy to overlook, especially in a humid stretch, and then you end up chasing slicer settings for what’s really a material problem. On bed level, I’d add that checking the first layer on a small patch before committing to a long print saves a lot of scrap. Slowing down the initial layer also makes small bed errors more forgiving.
I never understood why default profiles have first layers printing so fast (50-80 mm/s). I usually knock mine down to 20-30 mm/s especially if I know there will be small features or sharp corners prone to warping.
Also, call me old fashioned, but I like using a skirt for 1 or 2 loops to really prime the nozzle. Maybe something I just never unlearned from my Ender 3 days, but it’s actually really helpful, especially if you do multi-colour per object prints on the same build plate!
