I have had a couple of requests for the Voron 2.4 BOM of the kit we sell. Below I have a detailed list displayed.
You will have to build your own wiring harness but all supplies are included.
3D Printed Parts not included (but for sale as an addon with the kit)
VORON2.4 Configurator
Bill of Materials
|Category:|
Part Description: Qty:
Fasteners
M5x40 SHCS |22|
M5x30 BHCS |22|
M5x16 BHCS |35|
M5x10 BHCS |35|
M5 Post-install T-nut |68|
M5 Hexnut |16|
M5 1mm Shim |42|
M4x6 BHCS |7|
M4 Knurled Nut (DIN 466-B) |4|
M3x8 SHCS |187|
M3x6 FHCS |8|
M3x6 BHCS |11|
M3x40 SHCS |30|
M3x30 SHCS |25|
M3x20 SHCS |22|
M3x16 SHCS |20|
M3x12 SHCS |41|
M3x10 FHCS |4|
M3 Washer |3|
M3 Threaded Insert |110|
M3 Post-install T-nut |103|
M3 Hexnut |6|
M3 Hammer Head T-nuts |60|
M2x10 Self-tapping Screw |16|
Motion
Ø5x60mm Shaft, D Cut |4|
Ø5x35mm Shaft (trim to size) |1|
Linear Rail MGN9H 400mm |6|
Linear Rail MGN12H 400mm |1|
GT2 Open Belt Gates LL-2GT-9 (9mm wide) - 1200mm |4|
GT2 Open Belt Gates LL-2GT-6 (6mm wide) - 2000mm |2|
GT2 Belt Loop (6mm W) - 188mm |4|
GT2 80T Pulley (5mm ID 6mm W) |4|
GT2 20T Toothed Idler (5mm ID 9mm W) |4|
GT2 20T Toothed Idler (5mm ID 6mm W) |2|
GT2 20T Pulley (5mm ID 9mm W) |4|
GT2 20T Pulley (5mm ID 6mm W) |3|
GT2 16T Pulley (5mm ID 6mm W) |4|
F695 Bearing |20|
BMG Extruder Components Kit |1|
625 Bearing |12|
Electronics
BTT Octopus V1.1 |1|
Filtered Power Inlet (NA/UK) |1|
Thermal Fuse (125C) |1|
TMC2209 Stepper Motor Driver |7|
Orange PI Zero2 NOT INCLUDED |1|
Omron G3A-210B-DC5 SSR |1|
Omron D2F-01L Micro Switch |3|
NEMA17 Motor generic (equivalent to LDO #17HS19-2004S) |6|
NEMA17 Motor generic (equivalent to LDO #17HS08-1004S) |1|
Mini 12864 Display |1|
Medium Blow Fuse 5x20mm 8A (120v mains) |1|
Medium Blow Fuse 5x20mm 4A (220V mains) |2|
Mean Well RS-25-5 PSU |1|
Mean Well LRS-200-24 PSU |1|
Inductive Probe |1|
Phaetus Dragon High Flow Hotend Kit (24V) |1|
DIN Rail Mount Bracket for G3A SSR |1|
C13 Power Cord |1|
BAT85 Diode |1|
60x60x20 Fan (24V) |3|
40x40x20 Centrifugal Fan (24V) |1|
40x40x10 Axial Fan (24V) |1|
Vibration Management
Rubber Foot (1.5x.75", 38x19mm) |4|
Frame
OpenBuilds Billet Angle Corner Connector (2020) |4|
Misumi HFSB5-2020-530-LCP-RCP |4|
Misumi HFSB5-2020-470-TPW |10|
Misumi HFSB5-2020-450 |2|
Misumi HFSB5-2020-430 |1|
Misumi HFSB5-2020-340 |1|
DIN 3 Rails (35mm W) - 465mm |2|
Misc
Ø6x3mm Neodimium Magnet |8|
Single Sided Foam Tape 3mm Thick (5m) |1|
Single Sided Foam Tape 1mm Thick (5m) |1|
PTFE Tube (4mm OD 3mm ID) - 1000mm |1|
PTFE Tube (4mm OD 2mm ID) - 300mm |1|
4mm Threaded Bowden Coupler |1|
Cables
WAGO 221-415 Lever-Nuts |3|
Ring Crimp Terminal (16-22AWG, #6) |1|
Nylon Cable Ties, Small (.07-.10", 1.8-2.7mm wide) |42|
MicroFit3 Male Pin |40|
MicroFit3 Female Pin |40|
MicroFit3 Connector Receptacle 4 Position |4|
MicroFit3 Connector Receptacle 3 Position |1|
MicroFit3 Connector Receptacle 2 Position |2|
MicroFit3 Connector Plug 4 Position |4|
MicroFit3 Connector Plug 3 Position |1|
MicroFit3 Connector Plug 2 Position |2|
MLX Power Receptacle 3 Position (bed wiring) |1|
MLX Power Plug 3 Position |1|
MLX Male Pin |6|
MLX Female Pin |6|
JST XH Connector, 3 Position Male/Female Pair plus Pins |1|
Fork Spade Crimp Terminal (18-22AWG, #10) |5|
Female Spade Crimp Terminal (18-22AWG, .250", 6.35mm) |7|
Crimp Ferrule Kit (covering sizes 24AWG to 18AWG) |1|
Connector kit matching your controller choice (usually JST-XH) |1|
22-24AWG High-flex Wire (min 19 strand)(250ft/76m total) |1|
20AWG High-flex Wire (10ft/3m total) |1|
18AWG Wire (10ft/3m total) |1|
10x15 Generic Cable Chain (545mm) |1|
10x10 Generic Cable Chain (405mm) |2|
Panels
Coroplast Sheet - 483x503x4 mm |1|
Coroplast Sheet - 469x469x4 mm |2|
Acrylic Sheet Clear - 483x503x3 mm |2|
Acrylic Sheet Clear - 483x483x3 mm |1|
Acrylic Sheet Clear - 241.5x503x3 mm |2|
Build plate
Spring Steel Flexible Print Surface - 14"x14" |1|
MIC6 5/16" Plate - 14"x14" |1|
Silicone AC Heater w/ thermistor - 300x300mm |1|
Adhesive Magnetic Sheet - 14"x14" |1|
