About the Creality Halot Mage/Mage Pro/One/Sky/Lite/Ray/One category
This one is a bit of a list unfortunately
This Category is dedicated to any issues or problems dedicated to the Creality Halot Mage/Mage Pro/One/Sky/Lite/Ray/One resin printers.
Post up any Hints, Links or tricks you have learned using this printer.
If you have a problem, Post it as well and let the community help sort it out.
Hello from Calgary, Alberta, Canada…
For the last few weeks, I have enjoyed my Creality Halot One Resin printer.
To keep up with issues with 3D Printer hardware, I habitually update my software.
I have run into an Issue where the New software is causing problems with printing.
A YouTube ran through his print and came up with a corrupted layer, I reasoned why this was happening later after I had done the Downgrade (which made the Halot One Unusable) that the Layers needed more time to cure because the Resin I was using was Cement Gray and not clear
( I just got an Email back from CR Tech support link referring me to a [Google drive] which I have already tried to do) (CL-60 - Google Drive)
