Advice for this print please?
Ok so I am trying to print this file on my Ender 3 glass bed and it has starting not sticking as it is a very fine design. Everything else I print sticks perfectley to the glass bed.
Any suggestions?
A BIG thank you to HobbyMaker3D for making this file for me.
55da48ff6360eaf3952207de03446f1ab5328dd8_2_488x499
What material, speed, temp are you using? A brim might help due to the smallish footprint of the print.
Well I am using the default settings on Ultimaker. 200 and 50 for bed so I could tweak this? Is that correct?
Wood PLA on the label it says temp 205- 225.
Does Ultimaker define the temp?
Yes it does.
I have never used a wood filament but a buddy has and he prints it very slowly, 30mm/s.
Also it is very abrasive to the nozzle.
this is my settings for PETG, for temp and speed.
Retraction may be a factor for wood filament.
Simple solution PVA glue (Elmers safety glue from the dollar store)! It’s old school and it works.
Glue stick can work as well Pritt of similar. It is very close to PVA (typically EVA not a poly ethylene but just ethylene) effectively the same. if you have one or the other around already.
PVA glue is dirt cheap and found everywhere, I don’t know about the other.
Seems to be printing ok now.
