I love art Deco Lamps, but these have become expensive, so I thought it would make a nice 3D Printer project.
This artist produces some excellent examples with wonderful fine detail in his sculptures.
I printed the original but found it to be too small for my taste, so decided to scale the lady by 150% in meshmixer, and then remodel the other parts in solidworks to fit Canadian style bulbs. If any one would like my base & disc just send me a message.
I will use this thread to document the build process…
Below shows the new larger version, which will stand about 13" tall.
I tend to glue the separate parts together with super glue and then weld the parts together by brushing UV resin into the joints & use a UV flash light to set the resin. This technique is fast and allows you to build up the joint with resin.
