Best 3D Scanner for 3D Printing - Choose the Best
I researched about the best 3D scanner for 3D printing for the past few days because I need accurate scans for creating high-quality 3D printed models. I read reviews on popular 3D printing websites, tech blogs, and user forums, and they are marking these two as the best:
Revopoint MetroY Pro 3D Scanner for 3D Printing
Revopoint MIRACO Plus 3D Scanner for 3D Printing Handheld
However, I am having trouble deciding which one would best suit my needs and need your expert advice.
I mainly want a 3D scanner for 3D printing purposes. I plan to scan small to medium objects, mechanical parts, household items, and some detailed models. Accuracy, ease of use, and compatibility with common 3D printing software are important for me.
So which one should I buy? Any recommendations will be appreciated.
Thanks in advance.
If you want ease of use like an all-in-one, go with the Miraco.
But if you want the precision, go with the Metro Y, but it needs to be hooked up with a desktop/Laptop
another vote for miraco
I have been using the Revopoint Metro Y for a few weeks now, and the scan accuracy is honestly better than I expected for this size The setup was straightforward, and it handles complex parts really well without constant rescanning.For reverse engineering and inspection work, it’s saved me a ton of time compared to my older setup
https://www.amazon.com/Revopoint-MetroY-Pro-Industrial-Full-Field/dp/B0FPXB2B2R/
Have you already picked a scanner? If not, it might be worth considering skipping a dedicated scanner altogether. For medium objects you can get pretty good 3D models just from photos or video using modern photogrammetry software. For example: Artec Studio 20 | Professional 3D scanning solutions | Artec 3D
There are also free alternatives out there, though in my experience the quality and stability are usually not on the same level
Also you need a reasonably powerful computer for processing
