Warping is a common issue in 3D printing, especially when working with larger models or certain filaments like ABS. Many have tried adjusting bed temperatures, using adhesives like glue sticks, or even adding rafts and brims to tackle the problem, but it can still persist.
What are some of the most effective methods for preventing warping in 3D prints? Whether it’s tweaking printer settings, trying out different materials, or using specific bed surfaces, any tips or tricks that have worked well are welcome.
Let’s start a discussion and share advice on how to minimize warping and achieve smoother, more reliable prints!
I have used little disc like brims on corners when I print in ABS and PC. They work great but the problem is some slicers do not have these amenities. I always watch first time prints, without disc brims, because not all prints need them.
One other neat trick I have learned is that some slicers will allow you to adjust the gap between the brim and the part, this allows you to add a little bit more space making the brim easier to remove. As long as you don’t add too much space the brim will still do its job in helping the part to adhere properly!
There are some materials that partially adhere to others. For example pla sticks to Asa but not completely.
You can add 2-3 base layers to the file then print the first 2-3 layers in pla get good bed adhesion and switch to ASA and print the rest of the file and separate the pla after it is complete. It is a quick and dirty way to print more complex materials with out having a printer fully capable of doing it.
Jentec just posted a video but it’s not a new idea he just explained it better.
Wow that is incredibly interesting,
I have known for quite some time about using different materials as intermediates for supports, notable examples being PLA and PETG, or ABS and HIPS. But I had never considered using these materials as an interface for bed adhesion.
I hope this idea can be investigated more in the future, this could definitely be very helpful. I think I will start playing around with this myself, I have a couple of ideas that might be cool!
Thanks for sharing!
