Hi folks: BL Touch installed with Micro Swiss Direct Drive on CR 10S Pro V2. BL Touch had been doing a single centre glass probe until yesterday. Now it is doing (or trying to do) a 25 point touch which because it goes to 0,0 (left front corner) where the probe hangs beyond the glass edge and fails because it is not in contact with glass.
did you update your firmware where this happened? in your start G-code is there a G29? this starts unified bed leveling but it sounds like it’s not all defined in your firmware
Sounds like you haven’t taken into consideration that the nozzle is not in the same location as it was before. You need to make sure that’s taken into account. I had 3DPC install mine so I’m not sure what they did but my understanding is you can either update your firmware with the new values or set a new x and y offset to compensate.
