Bl touch replacement
Is there replacement bl touch kit for the cr10s pro v2 ( that includes the bl touch and cable)?
They are not printer specific. The BL/CR Touch comes as a kit with the cable, you just mount it on the gantry and plug it into the motherboard. This is assuming that your board is compatible and has a slot to plug it in. You may need to upgrade the firmware to use an ABL.
Looked around and not all sellers have a full length cable for it.
