I messed up my Bowden tube. I had a clog so I heated up the hot end and pulled the filament, and it snapped mid way up the tube. I would like to order Capricorn. What size do I get for the Ender 5 plus?
Just order the meter long length, it will give you a little extra, careful when you cut it don’t crush it, needs to stay perfectly round.
Hope this helps
Jason h
If you don’t have a dedicated Bowden tube cutter, the commonly available plumber’s tubing cutter used for ice makers, refrigerators and humidifiers works equally well.
https://www.canadiantire.ca/en/pdp/mastercraft-tube-cutter-1-8-to-7-8-in-0638778p.html
