Brim Prints, Part does not
Hey everyone,
I just completed my RepRap conversion on my printer.
Everything works great, the conversion of my CubePro was a great success!
I have my extruder stepper set for the correct steps/mm (that was a good hour and a bit of my night)
I sent a test print to the printer and the brim support prints fine, but when the print gets to the actual part, the extruder seems to stall/constantly skip steps. Is this an issue with my firmware? It extrudes fine when I do it manually.
I’m using Cura slicer and I will throw my Config.g below
Any help would be amazing!
Thanks,
Jake
; Configuration file for Duet WiFi (firmware version 3.3)
; executed by the firmware on start-up
; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Jan 21 2022 22:14:04 GMT-0500 (Eastern Standard Time)
; General preferences
M575 P1 S1 B57600 ; enable support for PanelDue
G90 ; send absolute coordinates…
M83 ; …but relative extruder moves
M550 P"Cube Pro Duo" ; set printer name
; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet
; Drives
M569 P0 S1 ; physical drive 0 goes forwards
M569 P1 S1 ; physical drive 1 goes forwards
M569 P2 S0 ; physical drive 2 goes backwards
M569 P3 S0 ; physical drive 3 goes backwards
M584 X0 Y1 Z2 E3 ; set drive mapping
M350 X16 Y16 Z16 I0 ; configure microstepping without interpolation
M350 I1 ; configure microstepping with interpolation
M92 X87.90 Y87.90 Z1066.67 E82.89 ; set steps per mm
M566 X8500.00 Y8500.00 Z12.00 E1000 ; set maximum instantaneous speed changes (mm/min)
M203 X4000.00 Y4000.00 Z1200.00 E1800.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z250.00 E500.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
; Axis Limits
M208 X0 Y-30 Z0 S1 ; set axis minima
M208 X280 Y290 Z190 S0 ; set axis maxima
; Endstops
M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop
M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop
M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !zstop
; Z-Probe
M558 P0 H5 F0 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid
; Heaters
M140 H-1 ; disable heated bed (overrides default heater mapping)
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
M950 H0 C"bedheat" T0 ; create chamber heater output on bedheat and map it to sensor 0
M307 H0 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
M141 H0 ; map chamber to heater 0
M143 H0 S300 ; set temperature limit for heater 0 to 300C
M308 S1 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e1temp
M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S280 ; set temperature limit for heater 1 to 280C
; Fans
M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency
M106 P1 S1 H-1 T45 ; set fan 1 value. Thermostatic control is turned on
; Tools
M563 P0 S"Extruder 1" D0 H1 F1:0 ; define tool 0
G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
; Custom settings are not defined
; Miscellaneous
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
T0 ; select first tool
is it that it gets to the part and doesn’t print or is it that after it’s extruded that much filament? my feeling is your cooling isn’t working as it should and the nozzle starts clogging after a while. is that possible?
Have an initial look at your config.g it looks ok, Can you post the Gcode file? think it may be cranking up on speed or down on temp. The Gcode would tell though
