I’m still having problems with the Z-offset, after installing Nic Wilson’s firmware for the CR10-S Pro V2.
On his facebook page I got the tip to look at a Youtube video “Calibrating Z-Offset With a BLTouch”.
Only one problem: half way he talks at looking to the Z-offset on the screen of the printer, but my otherwise stock CR10-S Pro doesn’t show the offset during the procedure.
Can someone help me with the correct procedure, using Ponterface?
The problem is solved. It took some tinkering and swithing between Ponterface and the leveling screen of the printer, but now the Z-offset is correctly stored in the eeprom, and will function correctly after re-initializing of the printer.
