My method isn’t super exciting. I go through the Teaching Tech calibration pages when I switch filaments - so an xyz cube, temperature tower, retraction tower, single wall cube for setting flow.
For resin I use the Monocure calibration matrix from their site. It gets a general look over then measure the holes with calipers and drop an m4 nut in the hex hole to check fit. Then perhaps most importantly I grab a permanent marker and write on the back of the print what the resin was and the settings so I don’t forget. I think that step will be key when I start mixing Monocure Flex100 in with Tuff so I have reference samples with notes of mix ratio and time.
