I always have trouble remembering how to set the various things on my printer so I made a list of some of them, if anyone wants them. This is ONLY for the E3V2 with the Jyers UI firmware upgrade. All settings are accessed through the display on the printer.
Ender 3 V2 Firmware Settings, Reset for Jyers UI/ Marln Firmware and Cura upgrades
Turn filament run out sensor on and set load to 420 and unload to 500
Turn power outage on
Calibrate Extruder - Esteps
Extrude 100mm of filament, measure it and calculate Esteps
Formula – 100/Measured extruded length = X
X * Current Estep (default = 93) = New Estep
Example – 100/98 = 1.020
1.020 * 93= 94.86.
Round off to nearest whole number or 95
Go to Control/Motion/Steps-mm/extruder and set to 95mm. Save settings. -
Set flow rates.
Print appropriate hollow flow cube by nozzle diameter. Calculate average and adjust flow rate.
Formula – Wall width for .4 nozzle (.4 nozzle with2 lines = 8mm)
/ Average measured Width = X
Flow width = X * 100
Example -- .8 /.79 = 1.012
1.012 * 100 = 101.26
Flow width = 101(whole numbers only)
Go to Control/Motion/Flow Rate and set new flow rate.
- Calibrate X, Y and Z Esteps
Print 20mm calibration cube. Measure X/Y/Z axis and adjust steps
Formula – Cube Axis Dimension / Actual Axis dimension = X
Current Esteps * X = new Estep
Example – 20 / 19.92 = 1.004
80 * 1.004 = 80.32
Go to Control/Motion/Steps-mm X, Y or Z axis and set appropriate new Esteps
- Calibrate PID
Run PID autotune
Go to Control/Temperature/PID/Hotend/Set temperature close to normal printing temperature/Autotune - wait until complete.
Go to Control/Temperature/PID/Bed/Set temperature close to normal printing temperature/Autotune - wait until complete.
- Set Cura Gcode for auto bed levelling for BL/CR Touch
Open Cura/ preference/Configure Cura/printers (pick printer to change)/machine settings/Start Gcode
Below the G28 command insert a line and add G29 ; Pre-print levelling and close.
