I recently installed a carbon fiber build plate on my CR10s Pro V2 and it seems the printer can’t get low enough to print on it. The Carbon Fiber Build Plate I used. I did also add the magnetic plates.
I’m not overly familiar with the CR10 but I’m assuming it is similar to the E2V3 in these regards. Doesn’t it have adjustable springs to set the height of the bed? Your Z stop should be able to be adjusted to reset the height that the gantry comes down to.
I didn’t even know it had the adjustable spring screws. Thanks for the help
