CR-10S PRO V2 Micro Swiss Direct drive Autoleveling
Hello,
I bought and installed my CR-10S PRO V2 Micro Swiss Direct drive.
The video (INSTALLING A MICRO SWISS DIRECT DRIVE ON CR-10S PRO V2 - YouTube) helped ALOT,
but now how do I get the Autoleveling to work? The bltouch goes off the printbed.
Thank you!
Did you set the distances from the probe to the print head? If not it doesn’t know were the probe is.
Your X and Y offsets have changed - we talk about the Z offset all the time, but the printer also needs to know the distance from the nozzle to the sensor in X and Y. I don’t know if that can be set from the screen or if you’ll need to recompile your firmware.
Hi @VagabondElf yes, you would need to set the M851, at least this is how I generally do it. If you connect to your printer via pronterface you can set them manually.
Tagged the wrong poster, Jason - it’s @Midianman that has the glitch. :smiley:
ops sorry my bad, I’ve been doing a lot of typing today. Sorry about that
I connect through Octoprint, so I will try and set the M851 and see what happens.
