CR-X Pro Micro SD Card Question
I need a new micro sd card for my Creality CR-X pro and i was wondering if you need to have a netac card or is it just recommended?
Thank you in advance.
Did the manufacturer recommend it?
You should be able to use any standard micro sd card with your printer.
I’ll just add any manufacturer will work the format may need to be altered, although unlikely. I would recommend staying under 16 GB. some printers will run larger even 128 GB but not all. 16 should work in every printer.
Are there any other specs required and thank you so much, this was a big help
