Recovering from a bad flu/cold (despite all my shots this fall - oh well) and decided to see if my RPi 2B could talk to the CR10 Smart Pro with OctoPrint
Yes, it could, once I located a USB A to USB C cable (I didn’t feel like disabling the Creality wifi board in the unit, just yet. Kitchen table’s tied up with another hobby (photography prints and frames
Went through the process of getting everything up to date, and loaded the Bed Mesh Visualizer plugin because I needed to confirm how far out of whack my bed is when heated. That was an interesting exercise.
These three shots over the past 2 hours show how variable this is, and what my deviation looks like - I’m reminded of a pringle…
mkay .98 variance… (yes, I’m rounding)
hmm. .93 variance…
eep - .88?
This is not encouraging to me to a) have nearly a full 1 mm difference, and then to see it shift down, over time (as I said, about 2 hours).
I’ve mentioned in other posts, that no matter how hard I try, I have poor adhesion for anything from the center line (150 mm mark on the X axis) to the right side of the bed (300 mm mark).
Looking at these mesh results, yup, we have a problem Houston. The fade height seems to be set to 2 mm, but that’s not helping, and my Z offset is -2.25 atm.
In the past, I’ve put some orange locktite on the screws the leveling knobs connect to so that I’d eliminate vibration issues backing things off. Doesn’t seem to be helping. I know the springs get fatigued, and these may just be ready to be retired. (My springs are the original ones and are now… 2 yrs. old?)
I had thought of trying to shim the PEI plate using layers of aluminum foil, and a bit of glue stick to hold them in place. I’m not sure I want to go the route of replacing the bed, heater mat, etc. If I’m going to drop that sort of coin, I’d rather look at a multi filament extruder system.
Within this community, what are people’s experience with the solid silcone spacers vs springs? esp. the (apparently) hardened ones?
It’s clear in my case, that even with ABL enabled, the CR10 Smart Pro’s not really doing a great job of adjusting for the deviations. I’m not even sure what’s considered acceptable at this point… but it would be nice to get it down to 0.0X variance.
I sense this may lead to yet another bit of insanity on my part to get the next thing dialed in on this machine…
