CR30 Print Mill Specs
Company - Creality
Release Year 2020
Mainboard Version 4.2.10
Drivers are TMC 2208
Greenback board
Below is a snip from the All3DP website.
GENERAL SPECS
  • Assembly: Semi-assembled
  • Mechanical arrangement: Cartesian Core-XY, infinite-Z
MATERIALS
  • Filament diameter: 1.75 mm
  • 3rd party filaments: Yes
3D PRINTING PROPERTIES
  • Layer height: 0.1 mm+
  • Feeder system: Bowden
  • Extruder type: Single nozzle
  • Nozzle size: 0.4 mm
  • Max. build volume: 200 x 170 x ∞ mm
  • Max. extruder temperature: 240 ℃
  • Max. heated bed temperature: 100 ℃
  • Max. print speed: n/a
  • Closed print chamber: No
  • Bed leveling: Factory leveled
  • Print bed: Carbon fiber
  • UI: LCD, rotary encoder
  • Connectivity: SD, USB
  • Built-in camera: No
  • Resume print: Yes
  • Filament sensor: Yes
SOFTWARE
  • Recommended slicer: CrealityBelt
  • Operating system: n/a
  • File types: n/a
DIMENSIONS AND WEIGHT
  • Frame dimensions: 535 x 656 x 410 mm
  • Weight: 16.5 kg
