Prints not coming out right? Well, it may be because the bed is not level on your LD-006! If that is the case, then here is a video on how to do just that! This video will guide you through the necessary step you need to take when you are needing to level the bed on this resin printer. This video could be used for many resin printers, for most of them are alike! Check it out!
