Hi all. I doubt this is specific to the CR10s PRO v2, however that’s what im printing with so I posted here first.
The unit is new. I’ve done the z-axis levelling, gantry level, bed level… etc… it actually was pretty good and the videos online are pretty straight forward.
for testing I am using a small print with a large (20mm, or sometimes even 40mm) raft so I can see how the first-layer is being put down… honestly it looks perfect… lines are straight and consistent… But the adhesion is HORRIBLE…
Im using AMZ3d filament, which worked perfectly on my (now retired) QIDI TECH 1.
My temp settings are; 200c for print temp (all layers, no variation) and 70c for bed temp for initial layer, then 50c … .Eco Mode is off. I’ve tried 195c for print, and 50, 55, 60, 70*c for initial layer… nothing is improving.
Ive cleaned the surface with IPA, which does seem to help… however its not a good enough adhesion, things are barely stuck on… a medium print would 100% not stay attached for the duration.
Im down to sanding the surface of the Creality PEI plate… which seems crazy… but I’ve no idea what to try next…
Can anyone suggest something?
