Creality Print Pause at height
If you move the layer bar, right side of the model, up or down and right click on it there is a “change filament” command. Is this a pause so that the filament can be changed during a print like the “pause at height” G code addition in cura.
This should be generally the same process. Creality print 5.0 might do it a little bit differently now, not entirely sure. If you want me to make an updated version using 5.0 just let me know and I will try and get something out for you!
It might help. I’m pretty slow.
I wonder why creality hasn’t put an automatic feature in creality print like there is in Cura, It makes this very quick and simple.
I did a little research and found out that both Creality Print and Orca, current versions, do have a very simple pause and/or filament change. No g-code editing to do either. In Creality Print right click the layer slider, in prepare it has a filament change button but in preview it has a pause button. Orca has the same or similar settings. This simplify’s things.
