Hi everybody,
My printer is a fusion3 f410 is a big build volume woth high speed travel around 350mm/s using a volcano hotend and bowden setup for the speed
Seems like I never really print fast as my main materials are abs, pc and nylon and print doesnt looks as good over 70mm/s
Recently upgraded the printer with insulated heated chamber, watercooled steppers and hotend
Now I’m wondering whatcI should do next to improve the print quality and speed, I see 3 options:
-I could move the extruder on top facing down and shorten the bowden tube a lot
-Or I could go direct drive with either the bondtech lgx ou the dyzeextruder pro
Or a bit of both and put a bondtech/dyze on top with shorter bowden tube
Not sure how the added direct drive weight will affect the travel moves, seems like a have more inconsistent retractions extrusions than ringing
Bondtech is lighter a little bit 287g vs 300 but the dyzeextruder have watercooling adapters for my heated chamber
What would you do? Any other options to consider?
Thank you!
