Ender 3 S1 Plus - poor print quality. It may be me
I recently bought an Ender 3 S1 Plus; my first with the bells and whistles. I had a hard time setting up the auto leveling system and the UI is confusing. My prints are bad; the layers are terrible and the nozzle strikes the infill line intersections as it moves across the pattern, usually triangles. Other than the prep for auto bed leveling I have not found a way to adjust the Z offset. I usually print telescope parts and setting circles with PLA at 0.28 LH and a PS of 60mm/sec. I have 2–E3 MAXs and 2-- E3 PROs with Bowden tubes and manual bed leveling. I have watched every video Creality After-Sale has and many others on You Tube. I still can’t figure out the problem. Any help would be greatly appreciated.
Welcome to the forum, Im glad you found us.
can you post up a copy of your start Gcode and let us have a look, Maybe something there is throwing you off
I know this thread is a bit old but thought I would throw in my 2 cents worth. I just purchased an Ender 3 S1 Plus also and having no issues with prints. I spent a lot of time at first doing manual levelling and now auto leveling woks very well. Auto levelling will not work good if your bed is above 2 mm out of level. The more level your bed the easier it is for the printer to calculate the settings. Run the manual levelling at least 3 or 4 times for best set up.
There is a setting in Cura that will slightly lift the nozzle as it travels to a new start point. I found this out after my nozzle was also rubbing on the model. Search for “Z hop” and turn it on. This may solve some of your problems. Also you can slow down your travel speed a bit as well. Default is 150 mm I set mine at 120. It does add a bit of printing time but worth it for quality prints.
You can also manually lift the Z during the first layer of you find it is too close. On the home page click on the setting at the top and click the Z function. Adjust up or down as required during the print. Good luck.
I’m sorry for the late response. After weeks of working with Creality and no results I found an answer on you tube. (3D Run Down). My bed was badly warped. I tried a glass bed form one of my E3 MAX printers and started getting good prints. After more than 8 weeks with no solutions, Creality finally agreed to send me a new hot bed and a new E3 MAX glass bed. It is a little quirky with the oversize bed but it is printing just fine. I have used the printer every day for the last 2 months with only an occasional small problem, but that is 3D printing. Thanks for the help. Jim
All is good, Glad you got it figured out. Let us know if we can help with anything else.
Thanks very much. Jim
