I am trying to print a rummoli bowl model on my Ender 3 v3 KE and I can’t seem to correct the nozzle striking the model as it prints. It looks like it is striking the infill because I have no problem when it is printing lines on the model. I have ran the temperature, flow coarse/fine adjustment (pass 1 and pass 2), and the pressure advance tests in Creality Print slicer (under Calibration menu) and made the adjustments.
I have slowed the printer speed and change temperatures to try and find a solution and no luck. If I reduce the printing speed while it prints (down to 40%) in Creality Print it reduces the noise which I take as not striking as much. I have also ran the Equipment self test on the printer before I tried to print again but no luck.
I have successfully printed a smaller version of the model so I am not sure why the printer is struggling with the larger model.
The Ender 3 v3 Ke runs a calibration before every print and I am perplexed. The gantry and bed are level from side to side (x), front to back (y) and for the gantry top to bottom (z).
I have tried printing this model 6 times to no avail. I am printing it right now and may be successful with the printer speed reduced now reduced to 40% but I am still getting noise from the nozzle hitting the infill but it is not as loud.
Any advice would be appreciated.
Tom
