Is this compatible together or do I gave to make modifications?
They are all compatible. You will need to print another fan shroud to make it compatible.
Where can I find IT?
I looked un thingiverse ans could nt find a New cover…
Here is the item you need to print: Satsana Ender 3 Fan Duct with Direct-Drive Extruder by butrejp - Thingiverse
@Dan have you done this kind of mod before? This is fairly extensive. If you have not try one at a time and maybe give it some time between. Personally I would do the extruder first.
I just finished a video covering this. If you’re still looking for some info, this might help you out. I would recommend getting the CR Touch since it’s compatible with the Creality printers and the BLTouch knockoffs can sometimes cause quite a few issues. If you go this route, you’ll have to modify the mounting bracket for the direct extruder by cutting one side of the tip. Ender 3 V2 - Direct Extruder Upgrade + CR Touch + Micro Swiss Install - YouTube
