Ender 5 Plus leveling wheels broken?
Hi gang, I’m having leveling issues. I had some issues and had the printer in the shop for a twice this year already. The problems are fixed, at least i think so, but when i got it home and immediately as it starts up it does the bed check and snaps off the BL touch…i’ve had this printer 2 years nothing like that ever happened before…Anyway I got a new pin and installed it and am trying to level the bed. TBH I have always found this printer terrible to level, but I finally found a good video that was helpful…however now I think i’ve got a new hardware issue…tbh I’m not even sure.
I level at home then do the AUX level to do the bed leveling with the wheels underneath…area 2…no issue…area 3 this is where the problem is…
The bed will not lower…if i turn clockwise the bed raises to all the way up…if i go counterclockwise the bed doesn’t move and the wheel just loosens to the point where it basically spins free…
I’ve tried starting the process with all the wheels tightened to top and lowering to do level same problem
I tried setting the wheels to lowest area and bringing up…same issue.
Is this a known or common issue with the nuts for leveling?
As you can see its not even close to level
This printer can print beautifully but damn it can be frustrating it has spent more time in the shop than printing this year. I am getting to the point of just selling it if this keeps up.
Hi there,
Would you mind taking some pictures and possibly a video of the wheel to help me see what is happening? The fact that the wheels spin in place seems rather odd!
Was there anything that happened to this printer before the wheels went all wonky? Something like it was dropped, or the nozzle crashed into the bed, or is was bumped. Just something that could explain why this has happened.
Thanks,
If it turns out that it is a bad wheel there are replacement ones available in metal (aluminum??) that are dirt cheap.
I can’t upload videos to the forum so here is a link to the video…
so the left corner is leveled fine but when i try to adjust for this corner the head is already tight to the plate and the bed needs to lower a bit but as you see i get no movement when i unscrew it…
Also the printer is fresh home from the repair shop. It did not get bumped or anything in transport. It apparently printed fine in the shop…but when i try a bigger print that goes beyond the small center area then the filament won’t lay down and the level is WAY off.
The threads on the leveling wheels are very fine. When you tightened them all the way up you may have stripped the nut in the wheel or the bolt on the bed.
I didn’t turn it tightly…just stopped when it stopped…I guess I need to replace them…3rd repair this year already…
Have you verified that the bed mount bolts are not turning with when you are turning the bed adjustment wheels?
Hi there,
Thanks for the video, if a picture says 1000 words then how many words does a video say :wink: ?
The wheel looks to be spinning fine to me, the sprint just doesn’t seem to be moving at all. Have you checked to make sure that it is not stuck? Try poking it with a screwdriver or an allen wrench or something to see if it will spring back. It’s possible that it could have gotten stuck on something when it was being re-assembled. It has happened to me countless times before!
Thanks,
