So what sort of extra hardware and electronics do you have?
This dosent have to be a total list, but ive been thinking of what i might need for future projects.
Heres what ive got roughly
Metric bolt and nut kit - beacuse metric is best
Led kit - beacuse i want to think ill use 10 out of the 500 in the kit XD
Assorted steel balls kit - i have a few projects/puzzles in mind, but havent acted on useing them yet.
Assorted spring kit - to compliment the assorted steel ball kit, but honestly probabilly should have gone with piano wire and just make my own springs as needed. Any suggestions on what to consider?
JST and soon a Dupont connector kit - beacuse i didnt know the jst kit wouldnt be sufficient for doing wire to wire connections.
Several sizes of circular rare earth magnets - for magnet things
Buck converters - for controlling correct power to particular extras… Still work in progress and should probabilly check with an adult im not a fire hazard XD jks
Hal sensors - for one of my goals of a filament diammeter/runout combo sensor
Fan controller - for my new control board and super sized fan… Work in progress
Numerous single use tiny tubes of super glue - so i dont waste a bunch if one goes bad
608 bearings - for bearing projects
Assorted switches - to turn on and off things
22 AWG wire - to wire up things
Then things blur into spare parts for the printer.
I think im missing resistors, capacitors, not sure what else, though my electronics skills are a bit weak and i havent fully thought out projects needing them yet.
Soooo what do you have on hand just cause?
