My resin print is consistently failing on the same location. I have had supports added but no effect. Any suggestions that could fix this problem? I have angled it forward 10 degrees but that did not help.
For a start check your model file for errors.
I’m not sure what kind of object you’re trying to print—could you send the model file so I can take a look? The details aren’t very clear in the picture, and there seems to be some deformation. You might need to control the post-curing time and temperature; the temperature might be a bit too high.
