Filament is not sticking to the bed, what should I do?
Exactly what is said, it took me days to get it “Close enough” to meet my standards (UBL 12x12 grid of probe points, corners no more then 0.03mm different) but it’s still not perfect (Stock ender 3 I can’t get any better, the X axis sags randomly on the right so until I go dual Z leads I will accept as is)
Also add that you need to ensure your leveling with everything setup exactly the same each time… Took me a few times to realize my glass bed (Official Creality bed) that USED to be flat is now bowed on two corners, if I don’t position it the same way it throws off the UBL and needs another tweaking… Also readjust Z offset every nozzle change, every belt tension adjustment, etc. and keep the Z leads properly lubricated… mine started to “slug” a bit throwing off my Z until I purged the left over Creality grease and the new one stuck.
