Files for ender 5 plus +sonic pad+Micro Swiss NG Direct Drive Extruder
Hello from Greece
I found you good
I own an enter 5+ with a Micro Swiss NG Direct Drive Extruder head, I recently bought a sonic pad, probably the sonic pad is the first edition. Unfortunately, there is no enter+ with bl , in the printer selection, see
Can someone email me all the instructions to install the sonic pad
Thank you
Hi there,
In order to install the sonic pad you will want to plug it into the printer using the usb port on the printer. Once this has been installed you should be able to select what model of printer you have and the sonic pad will flash the printer with the correct firmware. Once this is done allow it to finish the setup process and you will be off to the races.
If you are looking for a more in depth guide I will link a good one below!
Creality Sonic Pad Setup Guide — Creality Experts.
Happy Printing,
