G5 FGF granules 3d printer pellet printer recycle printer
Ibe heard little bits about pellet printers. Can you elaborate from personal expierence with it?
that’s just cool, way to be able to use up your old filament without having to extrude it
(10) Facebook
(10) Facebook
Will this system accept ground or fragmented recycled filament? It is much more sharp and angular that pellets? Others have found ground filaments need a vibrator or adjitator of some sort to feed as it tends to stick together.
Is this something this system will handle? Is the feed system separate so it can be attached to a different printer?
Facebook
https://www.facebook.com/AndyYuanAB/videos/192327889771602
Yes, if you have a grinder. you can recycle all plastic articles, including bottles, plastic waste, or something. thanks.
https://www.youtube.com/watch?v=7_2Z8sqAlFQ
so the unit has an adjudicator so sharp ground bits don’t stick together?
Yes, there is a sensor. BL-touch. thanks.
