Will Gorilla superglue adhere resin and PLA filament together once they have formed into two objects to stick together!
Basically any cyanoacrylate glue will work well for PLA, I have also had a lot of success using 2 part epoxy in the past!
What kind of gorilla glue? The type used on porous things like wood probably won’t work because they need to be able to penetrate the material being glued. That type is an expanding urethane material.
Would Gorilla 2 part epoxy work?
Yes epoxy works well, so does cyanoacrylate.
