Halot Mage problem
I am trying my Halot Mage printer. It printed the Berserker fine. When I attempt to print other models I get a paper-thin flat patty on top of the FEP. The settings on the slicer are the same for my model and the Berserker.
What am I missing here? Do the settings have to be changed on the Halot Mage? What settings should I use?
increase the support/raft ratio, need more surface area if its not sticking to the plate.
Creakily resin slicer does not have an option for rafts. My exposure time is 1.8 seconds on the slicing software
Halotbox doesn’t have adjust rafts, but they are there
add base in support tab, then change the base shape to skate.
I have halot ones but my bottom initial exposure is like 40 seconds for the first 2 layers. You really typically want to bake the first few layers to the metal plate.
Edit: Its Chitubox that has adjustable base ratios. But you can also just, import a flat disc and scale accordingly.
