Hi from another Nashville
I’ve been printing for about 2 years, but still a newbie, mostly trinkets & toys for grandkids and parts for my projects. I had a Creality Ender 3 but upgraded to the Creality K1 Max and I use their Creality Print 7.0 slicer. I use a number of different brands of filament, almost exclusively PLA. Most of what I printed worked well with the basic presets with me only making adjustments for supports or plate adhesion. Everything was working great then I couldn’t get anything to print (barely). The filament sporadically sticks to the plate and the second layer doesn’t stick to the 1st or any other. The filament comes off in hair-like form, not thready, thinner. I slowed the print speed down to one-third and it started printing better, but only for some of my filaments. So that’s why I’m signing up to this forum. First request for advice would be how to best use this forum?
Welcome!
Just like you already have. Share details and ask a question.
Have you had a clogged nozzle? If not, it sounds like its on its way. Did you get some nozzle needles with your printer? Raise the print head, pre-heat the nozzle, and work the needle up and down and move it around.
Check your Z-offset: it may be a little high (it seems to me that Creality printers always have the Z-offset too high).
Welcome to the forum. I started with a Creality Ender 3V2 and then moved onto the K1 MAX too.
I occasionally have the same problem. As stated try fiddling, the correct scientific name, with the Z offset. Another thing to try is to increase the “first layer line width” in the Quality pull out to 0.6mm from the standard 0.42mm. It is not advised to go any wider. Slowing the first layer down is important also.
I tried the clogged nozzle fix and it did not resolve the issue. I did what another forum recommended and checked youtube. One recommendation was to check the extruder gear bearings. They seemed a little lose, but not having replacement in hand I cleaned & reassembled it. I tested at the 1/3 speed and it worked much better, such that I got thru one of the parts I wanted NOW. When I revved it up to full speed, it was considerably better, but clearly NOT fixed. I’ve ordered the extruder gear assembly from Amazon.
As for z-offset, I’m going to try that, but I wonder why it would suddenly be a problem? As I said, everything was going well then it wasn’t. Regardless, I will scientifically fiddle :slightly_smiling_face: with it and let you know how it works.
This is a great place to get help with any 3D printing issues. It’s home to a huge community of experts who’ll be happy to help you figure out your Creality K1 Max. By the way, searching for reliable expert platforms and guides can also help you tackle challenges in completely different fields. For example, when I needed to learn about financial instruments, I followed a similar approach: I already used ecoPayz elsewhere and wanted to know whether it was practical for online casino deposits and withdrawals. The difficult part was finding operators that mentioned both the method and the important cashier conditions. I eventually used the Ecopayz accepted online casinos by https://Interacasino.com guide. It helped me create a shortlist, after which I checked fees, minimum amounts, verification requirements, and whether withdrawals were supported. That extra check mattered because accepting a payment method for deposits does not automatically mean it is available for cashing out.
I wanted to do some scientific fiddling with the Z-Offset, but I can’t seem to find it. I’m using Creality Print 7.0 as my slicer, is that my problem or am I just missing it?
On the K1 MAX it is on the front screen under settings (second from the bottom). Open that and then go down to expert settings, open and go to z offset. It can only be changed during a print so you will need to print out a test piece.
Why it would just happen now, that is one of the various mysteries of 3D printing. It just does!!!
