How to Dry 3D Printer Filament: Temperatures, Times & Methods (Bambu Lab, Ender & Prusa)
Quick answer
Wet filament causes stringing, popping and hissing sounds, weak layers and rough surfaces. Dry it in a filament dryer, food dehydrator, or low oven at the temperature that matches your material — roughly PLA 45–55°C, PETG 60–65°C, ABS/ASA 65–80°C, TPU 50–60°C, and Nylon 70–95°C — for several hours, then store it in a sealed box with fresh desiccant so it stays dry.
Why filament needs drying
Most 3D printing plastics are hygroscopic, meaning they pull moisture straight out of the air. Once water is inside the strand, it flashes to steam the instant it hits the hot nozzle. That steam disrupts the melt and shows up as popping or crackling noises, tiny surface bubbles, heavy stringing, poor layer bonding, and weak or brittle parts. PETG, TPU and Nylon absorb water fastest, but even PLA prints noticeably worse once it is damp. Drying drives that moisture back out so the plastic extrudes cleanly again.
1. Confirm the filament is actually wet
Listen while printing: sizzling, popping or faint hissing from the nozzle is the classic sign of trapped moisture boiling off. Look for stringing between parts, a rough or bumpy surface finish, inconsistent extrusion, and prints that snap easily. Filament that has gone brittle and cracks as it unspools is very likely waterlogged. If you see these symptoms even after tuning temperature and retraction, drying is the next step.
2. Choose the right temperature and time
Set the dryer just below the plastic’s softening point and give it enough time for the heat to reach the core of the spool. Typical starting points:
  • PLA: 45–55°C for 4–8 hours (PLA softens near 60°C, so never exceed about 55°C or the coils can fuse together on the spool).
  • PETG: 60–65°C for 6–12 hours.
  • ABS / ASA: 65–80°C for 4–7 hours.
  • TPU: 50–60°C for 4–6 hours.
  • Nylon / PA: 70–95°C for 6–12 hours — the most hygroscopic common material, so it needs the highest heat and longest time.
  • PC (Polycarbonate): 70–90°C for 6–8 hours.
When in doubt, start lower and longer rather than hotter. A whole spool holds a lot of thermal mass, so a few extra hours rarely hurts.
3. Use a dedicated filament dryer
A purpose-built filament dryer is the easiest and safest option. It holds a stable temperature, usually includes a humidity readout so you can watch progress, and many models let you feed the filament straight to the printer while it dries. Set the material profile or temperature, run it for the time above, and you are done.
4. Use a food dehydrator
A food dehydrator with an adjustable thermostat works well and often fits a spool once the trays are removed. Confirm the real temperature with a separate thermometer, because dehydrator dials can read a few degrees off. It is a cheap, reliable alternative to a dedicated dryer.
5. Use an oven only with caution
An oven is a last resort. Many home ovens overshoot their set point by 10–20°C and cycle well above the dial, which can soften or melt PLA and warp the spool. If you must use one, set the lowest possible temperature, verify it with an oven thermometer, keep the door cracked to vent moisture, and never use a gas oven or one with an exposed heating element near the filament. Never microwave filament.
6. Store filament so it stays dry
Drying is only half the job — keep moisture out afterward. Store spools in an airtight container or vacuum bag with fresh desiccant, or in a sealed dry box. Colour-indicating silica gel is handy: it is usually blue or orange when dry and turns pink or green as it saturates, so you know when to recharge it. Aim to keep the environment below about 15–20% relative humidity.
7. Dry while you print for thirsty materials
PETG, TPU and especially Nylon can re-absorb enough moisture to misbehave within a day in a humid room. For these, print directly from a heated dry box or a dryer with a filament pass-through, or use a sealed feed system like an enclosed spool box with a PTFE tube to the extruder. This keeps the strand dry from spool to nozzle.
Frequently asked questions
How do I know when the filament is fully dry?
The popping and hissing at the nozzle stop, stringing drops off, and the surface finish smooths out. A dry box with a humidity gauge showing a low, stable reading is the clearest confirmation.
Can I dry filament in a normal kitchen oven?
You can, but carefully. Home ovens often run much hotter than the dial suggests, so use the lowest setting, check it with a thermometer, and watch closely — overheating can fuse or deform the spool.
How long does filament stay dry after drying?
It depends on humidity. In a sealed box with good desiccant it can stay dry for weeks or months, but left out in a humid room, PETG and Nylon can become printable-wet again within about a day.
Does drying wear out or damage filament?
No, drying at the correct temperature is safe and can be repeated whenever needed. Damage only happens if you exceed the plastic’s softening point, which fuses the coils or deforms the spool.
