Experiencing Micro LiDAR errors or misalignment issues with your Bambu Lab X1E can be challenging. Here’s a guide to help you troubleshoot and resolve these problems:
- Clean the Calibration Board and LiDAR Lens:
- Ensure the calibration board is clean and unobstructed.
- Gently clean the LiDAR lens using a microfiber cloth to remove any dust or smudges.
- For detailed cleaning instructions, refer to Bambu Lab’s official guidance.
- Inspect and Reconnect the USB-C Cable:
- Power off the printer and check the USB-C cable connecting the Micro LiDAR for any signs of damage or loose connections.
- Unplug and securely reconnect the cable to ensure a stable connection.
- Some users have resolved issues by replacing a faulty USB-C cable.
- Update Firmware:
- Ensure your printer’s firmware is up to date, as updates may address known LiDAR issues.
- Check Bambu Lab’s official website or support channels for the latest firmware updates.
- Perform a Factory Reset:
- If problems persist, consider performing a factory reset to revert settings to their defaults.
- Note that this will erase custom settings, so back up any important configurations beforehand.
For a visual guide on cleaning the Micro LiDAR sensor, you might find this video helpful:
How to Clean the Micro LiDAR Camera Sensor on the BambuLab X1 Carbon -
