How to pull tree supports of easier
My tree supports are difficult to pull off. I am damaging some of my models pulling them off. Is there a way to make the tree supports easier to remove? I am using tree (slim) supports.
What settings for the supports are you using, default or have you changed some.
Send a snapshot of what you have used.
try increasing your top z contact distance a touch. generally I use 0.22 but on occasion 0.3. you can also increase the top interface layers a bit it makes the support unified as one part.
these will make the overhangs a bit rougher.
