Usually this is a simple solution! Check that the voltage selector on the side of the power supply is switched to 110/115V. For North America, our power receptacles are supplied with 110/115 V AC at 60 Hz nominal. So the printer will only work properly if the correct voltage selection matches the incoming power from your outlet.
