I print 518mm round by 14mm tall setting circles for telescopes in 4 sections and I do a color change from matte black to white at 12.6mm layer height. I am now using Ender 3 MAX and Ender 3 S1 plus printers that require a manual color swap.
I need to buy a two color printer very soon. I was ready to buy an IDEX printer but then read that the two heads may interfere with each other on large prints. Each of the four sections I print is at least 268mm x 258mm; taking up most of the bed. It is not my first choice but I may have to go to a single hot end with dual extruders.
Any suggestions or printer recommendations will be greatly appreciated. Thanks much. Jim
Any two headed printer is going to have problems like that ans /or reduced print area. You can get printers with multiple changeable print heads but $$$$$$$$$$$$$$$$$$$$$$
Another option is to go to an MMU. Prusa makes one and I have seen videos of people who have modded them for any printer.
ERCF is also an option for MMU.
I will add in here that if you choose to go with the ERCF you will need to have a machine that runs klipper. From what I know the ERCF does not work with any marlin based firmware’s, but if you choose to go this route the MMU’s can be very useful for tons of different projects!
