Hi! Question. I am running an ender3 v2 as well as an ender 5 plus, both with direct drives, both with glass beds and both using glue stick adhesive on the beds. I did the same exact test prints on both printers
Ender 3v2 I was using white value PETG
Nozzle 240
Bed 70
Ender 5plus I was using blue value PETG
Nozzle 240 bed 75
From my pictures below is it the settings in the slicer that needs to change or am I doing something else’s wrong?
I am using the latest version of CURA.
I ran these 4 tests because I noticed when I was printing normal stuff I was getting failed prints.
the 5 plus is deff cleaner, but the temp is too high. I would suspect it to have to print somewhere about 220, the higher end temps are looking a little melty
not sure if it’s just me but the filament looks cooked, Printed too hot. Cannot tell if the second pic is a side or bottom. If it’s the bottom there is some under extrusion as well, The upper pic looks like its a model, or there is a belt loose.
