Issues with a sort of ringing and jagged cuts with print
Hello!
We’ve had our K1 Max for a while now with minimal issues. Suddenly, our newest print is having this consistent issue of ridges and almost imbalanced looking printing as it gets towards the end of the print. It is primarily a vertical print, and the higher it goes, the more frequent these rings get.
Our first thought is that maybe it is getting wobbly towards the top? But we have slowed down the printing speed so much and it is still occuring.
A local expert has said it shouldn’t be the file, however, we are test printing another different file now.
Here are some photos:
https://imgur.com/a/RHNMRPp
Any help and expertise would be very much appreciated!
Could be wet filament potentially, what material are you using for this?
Hello! We are using PLA+ from ESun
I ceranally could be we filament. I also could be a worn ou nozzle as well.
Turns out it was the print wobbling as it got through to the top part. Adding supports fixed the issue! Thanks for the help guys.
