Klipper error virtual end stop
I have a BTT Manta M8P with CB1. Klipper, Moonraker, Mainsail installed and board flashed. The board is currently powered by USB and Mainsail connected without issue. Now I am modifying the basic Manta M8P printer cfg file for my Ender 5 plus and I now get this error when I try to config z-axis virtual endstop and BLtouch. My printer.cfg file is below. What am I missing here? Any ideas?
Klipper reports: ERROR
Probe virtual endstop only useful as endstop pin
[include mainsail.cfg]
This file contains common pin mappings for the BIGTREETECH Manta M8P
To use this config, the firmware should be compiled for the
STM32G0B1 with a “8KiB bootloader” and USB communication.
See docs/Config_Reference.md for a description of parameters.
[stepper_x]
step_pin: PE2
dir_pin: PB4
enable_pin: !PC11
microsteps: 16
rotation_distance: 40
endstop_pin: ^PF3
position_endstop: 350
position_max: 350
homing_speed: 100
[stepper_y]
step_pin: PF12
dir_pin: PF11
enable_pin: !PB3
microsteps: 16
endstop_pin: ^PF4
position_max: 350
homing_speed: 100
[stepper_z]
step_pin: PD7
dir_pin: !PD6
enable_pin: !PF10
microsteps: 16
endstop_pin: ^PF5
endstop_pin: probe:Z_virtual_endstop
position_min: -3
position_max: 400
homing_speed: 10
second_homing_speed: 3
homing_retract_dist: 3
Motor4
The M8P only has 4 heater outputs which leaves an extra stepper
This can be used for a second Z stepper, dual_carriage, extruder co-stepper,
or other accesory such as an MMU
#[stepper_]
#step_pin: PD3
#dir_pin: PD2
#enable_pin: PD5
#endstop_pin: PC0
[extruder]
step_pin: PC9
dir_pin: PC8
enable_pin: !PD1
microsteps: 16
rotation_distance: 33.683
nozzle_diameter: 0.4
filament_diameter: 1.75
heater_pin: PE3 # HE0
sensor_pin: PA1 # T0
sensor_type: Generic 3950
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 260
[safe_z_home]
home_xy_position: 180, 180
speed: 100
z_hop: 10
z_hop_speed: 5
[bltouch]
sensor_pin: PB2
control_pin: PB1
x_offset: -45
y_offset: 0
z_offset: 0
speed: 3.0
pin_up_touch_mode_reports_triggered: False
[bed_mesh]
speed: 100
horizontal_move_z: 8
mesh_min: 50, 50
mesh_max: 300, 300
probe_count: 3, 3
[filament_switch_sensor material_0]
switch_pin: PC1
Motor6
#[extruder1]
#step_pin: PA10
#dir_pin: PD15
#enable_pin: !PA15
#heater_pin: PB5 # HE1
#sensor_pin: PA2 # T1
[filament_switch_sensor material_1]
switch_pin: PC2
Motor7
#[extruder2]
#step_pin: PD12
#dir_pin: PD11
#enable_pin: !PD14
#heater_pin: PB6 # HE2
#sensor_pin: PA3 # T2
Motor8
#[extruder3]
#step_pin: PD10
#dir_pin: PD8
#enable_pin: !PD9
#heater_pin: PE1 # HE3
#sensor_pin: PA4 # T3
[heater_bed]
heater_pin: PB7
sensor_pin: PA0 # TB
sensor_type: ATC Semitec 104GT-2
control: watermark
sensor_type: EPCOS 100K B57560G104F
control: pid
pid_Kp: 690.34
pid_Ki: 111.47
pid_Kd: 1068.83
min_temp: 0
max_temp: 130
min_temp: 0
max_temp: 130
[fan]
pin: PE6
[heater_fan fan1]
pin: PE0
#[heater_fan fan2]
#pin: PC12
#[heater_fan fan3]
#pin: PE5
#[heater_fan fan4]
#pin: PE4
#tachometer_pin: PC13
#[heater_fan fan5]
#pin: PB8
#tachometer_pin: PC14
#[heater_fan fan6]
#pin: PB9
#tachometer_pin: PC15
[mcu]
serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_290019000F504B4633373520-if00
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 2500
max_z_velocity: 5
max_z_accel: 100
TMC2209 configuration
[tmc2209 stepper_x]
uart_pin: PC10
#diag_pin: PF3
run_current: 0.800
stealthchop_threshold: 999999
[tmc2209 stepper_y]
uart_pin: PF13
#diag_pin: PF4
run_current: 0.800
[tmc2209 stepper_z]
uart_pin: PF9
diag_pin: PF5
run_current: 0.650
#[tmc2209 stepper_]
#uart_pin: PD4
##diag_pin: PC0
#run_current: 0.650
#stealthchop_threshold: 999999
[tmc2209 extruder]
uart_pin: PD0
run_current: 0.800
#[tmc2209 extruder1]
#uart_pin: PF8
#run_current: 0.800
#[tmc2209 extruder2]
#uart_pin: PD13
#run_current: 0.800
#[tmc2209 extruder3]
#uart_pin: PC7
#run_current: 0.800
TMC2130 configuration
#[tmc2130 stepper_x]
#cs_pin: PC10
#spi_bus: spi1
##diag1_pin: PF3
#run_current: 0.800
#[tmc2130 stepper_y]
#cs_pin: PF13
#spi_bus: spi1
##diag1_pin: PF4
#run_current: 0.800
#[tmc2130 stepper_z]
#cs_pin: PF9
#spi_bus: spi1
##diag1_pin: PF5
#run_current: 0.650
#[tmc2130 stepper_]
#cs_pin: PD4
#spi_bus: spi1
##diag1_pin: PC0
#run_current: 0.800
#[tmc2130 extruder]
#cs_pin: PD0
#spi_bus: spi1
#run_current: 0.800
#[tmc2130 extruder1]
#cs_pin: PF8
#spi_bus: spi1
#run_current: 0.800
#[tmc2130 extruder2]
#cs_pin: PD13
#spi_bus: spi1
#run_current: 0.800
#[tmc2130 extruder3]
#cs_pin: PC7
#spi_bus: spi1
#run_current: 0.800
[board_pins]
aliases:
EXP1 header
EXP1_1=PE9, EXP1_2=PE10,
EXP1_3=PE11, EXP1_4=PE12,
EXP1_5=PE13, EXP1_6=PE14, # Slot in the socket on this side
EXP1_7=PE15, EXP1_8=PB10,
EXP1_9=, EXP1_10=<5V>,
EXP2 header
EXP2_1=PB14, EXP2_2=PB13,
EXP2_3=PF7, EXP2_4=PB12,
EXP2_5=PE7, EXP2_6=PB11, # Slot in the socket on this side
EXP2_7=PE8, EXP2_8=,
EXP2_9=, EXP2_10=PC5
See the sample-lcd.cfg file for definitions of common LCD displays.
#[bltouch]
#sensor_pin: PB2
#control_pin: PB1
Proximity switch
#[probe]
#pin: PF6
#[output_pin ps_on_pin]
#pin: PC3
#[neopixel my_neopixel_1]
#pin: PC6
#[neopixel my_neopixel_2]
#pin: PA9
#[hall_filament_width_sensor]
#adc1: PC5
#adc2: PB0
Looking at the error it sounds like the BLtouch Pin is not in a PWM connection.
Going to have a bit more detailed look at your .cfg file but that’s basically what the error is saying.
I am assuming its physically plugged into a PWM but the config file is setup to look at a 2pin switched input.
Right now nothing is plugged into the board… it’s not in the printer yet - just on the bench powered by USB. Does the BL touch need to be plugged in? I guess it would make sense if it does…
Yes. The BL Touch needs to be plugged in.
In the future, you should read through the “klippy.log” file as it has a lot of really useful information and, if you still can’t find the problem, then post the entire file as it has the latest printer.cfg that is running and more detailed information.
You might also want to join the Klipper Discourse group: https://klipper.discourse.group/
Thank you - makes perfect sense. I have joined the Klipper Discourse group as well as r/klippers. :slightly_smiling_face:
thanks, Myke, great advice.
Finally got back to this and got it figured out. EVERYTHING is case-sensitive! The “endstop_pin: probe:Z_virtual_endstop” in my config file had a capital Z… simple as that. I guess the klipper error verbiage can be somewhat nebulous.
thats amazing, does anyone know if Klipper is based on a Linux Kernel? would make sense for the case sensitivity in that case?
Klipper is a Linux application not an operating system or kernel. You need a host system running Linux to run it as well as a user interface (the most popular one right now is “Mainsail” which is part of the installation package).
If you’re going to test out Klipper for the first time, I HIGHLY recommend that you use a Raspberry Pi 4B (with the 3B) being a close second even though they’re somewhat expensive right now (I believe CanaKit has some packages available that aren’t terrible in price when you consider you’re getting the power supply, case, keyboard, etc. with the Raspberry Pi).
If you look around, people are publishing that they’re using Pi Zeros, and Orange Pis as well as old laptops running Linux with Klipper and these approaches are significantly harder to set up than using a Raspberry Pi 4B and will have performance issues that are very hard to track down and resolve.
