Having an issue setting up my printer properly in CURA it seems,
I have run the xy test print and can get the two heads pretty well aligned to my satisfaction but when I try to use the profile the way I’m reading it’s to be set up through the instructions the extruder heads will either crash in to one another or the print from the second head (left side) is off of the right side of the build plate.
