I think I have an issue with my hot end. I was getting blobs of filament when printing, and when I took off the fan shroud, saw the following:
Do I have to replace the Hot End or just clean it? How do I clean it? Acetone bath?
if you’re are careful you can take it apart hot (but turned off) and all the gunk will come off before it’s cold. this happens when the nozzle isn’t tightened against the heat break inside and the filament squeezes out. careful around the heater and especially the thermister wires they’re delicate and check for shorts before you put it back together.
Don’t understand - hot but turned off… How do I do that? Can I just heat it to about 200 then use a needle or something to flake it off? Once I do that, I can remove and fix the gap, correct?
well, it doesn’t go cold right away. if you short the thermister while tools around those parts while it’s live it could burn the motherboard out. It’s happened to me twice I let it get cold. heated it to 215, turned it off then scraped the plastic off (the first time mine was a large glob that was still cold on the outside) then use your tools to take it apart while the plastic is still molten/soft
You can clean it while it’s on; just do not use a metal wire brush to clean it. I use round tooth picks or BBQ skewers to scrape off the majority of the plastic, then a piece of scrap cloth to finish up.
When you press the Bowden tube into the top of the hot end, it is supposed to go all the way down and rest flush against the top of the nozzle.
Awesome explanation! Thanks!
Just 1 more question. I saw a video that the nozzle should NOT be tight against the heat block.
Is that correct?
that’s is correct, if it is then it’s not tight against the heat break. so set the heat break far enough into the heat block that when you tighten the nozzles they can’t quite reach the heat block.
I screw them in by hand and get it hot to tighten with a wrench. then retighten after a print or 2 to make sure.
Oh and after you get it back together make sure your bed is level and check your Z-offset it might be different
So what I saw was about 1 mm or so gap between the nozzle and the block, correct?
The nozzle should not be tight in the heat block.
Sorry if I am asking the obvious questions - still learning!
So the PTFE tube is what the nozzle is tightened against?
That depends on your parts. on mine, the PTFE tube stops at the heat break and it’s all metal down to the nozzle. if yours has a PTFE tube that goes through then yes the nozzle tightens against that and the fitting at the top that holds the Bowden tube should be tightened last to press the tubes all together inside so no gaps open up.
It’s whatever the CR 10S Pro V2 comes with…
I don’t have an “all metal” hot end, so my advice didn’t factor it in since I’m not used to the procedure that applies to it.
Take your nozzle off. If you can push the Bowden tube all the way through and out the other end, then you don’t have an “all metal” hot end (like mine). In that case I would argue that you DO want to tighten the nozzle to the heat block (no gap). My procedure for installing the nozzle is as follows:
The problem (actually, there are are a couple) with the non-all-metal hot ends is that there’s nothing for the nozzle to press up against, other than the heat block. The Bowden tube, being a type of plastic itself, is flexible and doesn’t supply a secure surface to tighten against and so you can’t really be sure that you’ve sealed off the nozzle just by the feel of it. You can tighten the nozzle to the heat block and still have a gap and not know it until plastic starts slowly oozing out the sides.
With the all-metal heat breaks, as @Glenn says, you can feel the nozzle bind against the bottom of the heat break and so tightness = good seal.
So, unless you already know the answer, do the Bowden tube test. If it goes all the way through, use my method. If it doesn’t, use @Glenn’s.
