I am wondering if anyone has experience using liqurete composite X resin? It is the one with ceramic particles. I am making a part that needs to withstand 130 ft/lbs of force.
Please hit me up with any user experience, print times, curing process and length, or another resin i might want to try. I have used the whole line of siratech and it keeps breaking. Orignal part was molded with nylon.
@Brnbar01 I have no experience with resins. I am very interested to hear the answers. I have a single comment and you are likely aware. The design can add or subtract strength and ofter the original part is made for a different process and can be altered. Something to keep in mind.
I have only printed with the composite X on the Creality LD-006 using their recommended settings. I didn’t really use supports as the parts were designed a certain way. I cant speak to the exposure settings for your machine but I would try maybe a larger ball tip on the support ends where it meets the model. might give a better hold instead of pulling off and sticking to the FEP
I got in contact with liqucreate and they went above and beyond! Helped me dial this in. The main things were slowing everything down and upping the exposures. Working great, now.
